Getting water in the sides of the car.
It enters down the windows etc. the way to correct it is there are a number of plug holes along the sills on both sides of the car. if you look underneath you will see them, just undo them and let the water out, they sometimes get blocked, just use a big coin to remove the plugs.
Just ensure the car is level or drive a little with the bungs out just to shift it!!!
Parts of the long sills are self draining,
On occasions you can hear the fuel in the tank moving but you recognise when it is full etc.
DONT PAY
it is very easy to do.
There are drain plus on the side of car where you jack up the car.
The black rubber jack points, inside the middle there is a plug you take out.
just use a screw drivers and wiggle it out.
took me 15min
