HELP WITH REAR SAM E COUPE FACELIFT AND VEDIAMO
Old 03-07-2016, 06:37 PM
luirema's Avatar
E COUPE 220 CDI
Hello
I have a E coupe 2011 and i doing the facelift.
I need help for coding my new rear lights by vediamo.
I have cables repositioned and it works but not perfect , I need to know the values that must change and would appreciate if someone can read his rear sam in a new facelift coupe.
If some body need help with conections I can help.
Thank you
Old 03-08-2016, 01:19 PM
Plutoe's Avatar
Received 1,028 Likes on 956 Posts
1999 E300TD
You don't need Vediamo to do the coding----use DAS Xentry and code the SAM--it's all seamless!!
Old 03-08-2016, 01:44 PM
luirema's Avatar
E COUPE 220 CDI
Hello
But is posible coding offline?
Is posible you tell me how can i do it?
Thank you
Old 03-08-2016, 02:52 PM
Plutoe's Avatar
1999 E300TD
What version of DAS Xentry are you using. What is the VIN of the car you are working on!!
Old 03-08-2016, 03:11 PM
luirema's Avatar
E COUPE 220 CDI
My vin is WDD2073021F135867
My xentry sofware version is 14.2.1.1
I use c3
Old 03-08-2016, 04:10 PM
Plutoe's Avatar
1999 E300TD
Thanks----First I am going to suggest that you practice the adaption by using DAS Xentry simulation----put your VIN in and go to control module adaptions---then select the manual method of coding the SAM you want----try that and advise!!
Remember that if your SAM's do not have the facelift capability you will not be able to do what you want, not with Vediamo or DAS xentry--that is very important!!
Old 03-21-2016, 06:23 PM
luirema's Avatar
E COUPE 220 CDI
I test using xentry simulation but offline is imposible coding.
Please, if somebody can read a rear sam by Vediamo in his facelift coupe i would appreciate.
Quick Reply: HELP WITH REAR SAM E COUPE FACELIFT AND VEDIAMO
