Hello,
My car recently had done replacement of timing chain, sprockets, tensioners, spark plugs and oil. Unfortunately it all needed to be replaced because chain was stretched and started to eat teeths on timing gears. But now after the Whole process (expensive!) engine sounds bit strange when well warmed. Here's short video:
Have You got any idea if it's ok? It happens only when engine is well warmed. I also have check engine indicator but it happens only when I accelerate hard. Last time it went off after trip on the motorway for 2h but then came back few days ago when I accelerated 0-60. Few weeks ago it was crankshaft position sensor failure and it came on because of same reason as now so what do You think it might be? Lambda sensor maybe?
Currently Active Users (1)
