Reliability question regarding 2012 E350 cabriolet
Hi Guys,
I just purchased a 2012 E350 cabriolet with 44K miles on it. The warranty has expired and I turned down an extended warranty through my credit union. I sold a 2006 280SLK to purchase it. I owned the SLK for 5.5 years and had very few issues. I ran the VIN through 2 Mercedes dealerships and was told the car only had standard maintenance done. My friend has two older Es, a 2001 and 2008, and hasn't really had any major problems. What are the issues people are having with 2012s? Should I have gotten the extended warranty? Thanks for any info. |
You don't buy a Mercedes to save money so you shouldn't scrimp on things that count. Same goes for medical insurance.
Do you have specifics. This is my second Mercedes and I have owned several Alfa Romeos. There is a difference between doing standard maintenance and having lots of mechanical/electronic issues. My last car was a 2006 SLK with very few issues. Can you list problems you have had?
if i have the option, ill get the extended warranty for peace of mind.
also, you really cant compare your experience with a 2006 slk and a 2012 E cab. more tech, more gadgets, more electronics, more chances of stuff up. look at it this way, your manual window riser from the 80's will outlast your electric power windows today (maybe), but you get the idea. but i would do all necessary maintenance on time (catch up if your car is behind) and i wouldnt worry too much. |
Thanks so much! Have you had any major issues? Engine, transmission, major electrical?
ive had 123's, 124's, 202, 209, 170, 210, 211, 212 sedan & coupe and a 204. not all of them had warranties.
now knock on wood...apart from the rear sam on my E coupe which dealer quoted/fixed south of AU$3000 iirc (under warranty), never had any major issue that i can remember. little things here and there but nothing major. some i even fix on my own. |
Thanks for the reply. Your experience has been the same as my friend's. I'm hoping for many years of reliability and wish you the same.
thanks mate! just hope for the best but expect the worst.
main thing is, imo, you have one of the most beautifully shaped convertibles out atm. enjoy it!. PS: and if you come across any problem, post it here or on the W212 section, sometimes it can get slow in here but members help when they can. |
