Tilt wheel doesn't go up or down
2011 e350 cabriolet, 2017 e300 4matic atic,
The tilt wheel feature on my 2011 E350 Cabriolet stopped working the other day. Exactly one year ago the same thing happened, the dealer said it had to be retrained to the tune of $115.00 and it was fine for a year. This also affects the easy entry feature. I saw somewhere that this can be caused by low voltage. Had the battery checked and I'm getting 12.3 volts. Any one else have a similar problem.
marctep (12-13-2016)
My battery died the other day (I don't know how) but I had a tow truck jump the car and it's been fine since, only the tilt wheel does not lower when I start the car for the first time each day, all I have to do is manually lower it just a little, then press the memory button on the door and it will go into position. Then after that it will be fine for the rest of the day, it will go up and down. But then when I park overnight, the next morning it will not go down on it's own. So it does seem like it's related to your battery voltage.
Actually, when your battery died it reset the system. It's not a voltage thing. The reason it does not auto tilt now is you have to change the setting to entry exit raise the steering wheel. It's default is off so when the battery died it went back to default. Mine stopped moving even manually and the dealer reset it.
