wheels are too big :(
Old Jan 19, 2018 | 01:35 PM
e550blee's Avatar
2010 e550 coupe
just got AMG rims that are 19 inch. I currently have 18 inch on my 2011 e550 coupe. I tried putting the new ones on my front and it touches my suspension. anybody know what tires I can run if its 19 inch rims. they have 255/40 19 and like I said are too big
Old Jan 20, 2018 | 01:25 AM
ffr2014's Avatar
2012 E550 Coupe, 2013 Escalade ESV, 2013 Lexus GS350, 2003 Honda VFR, 2017 Yamaha Kodiak 700 EPS SE
This is my setup on stock suspension on 2012 E550 Coupe (no rubbing and flush fitment):
Wheels:
Vertini RF1.1
Front 19x8.5 ET40
Rear 19x9.5 ET45
Tires:
Continental ExtremeContact DWS06
Front 255/35-19
Rear 285/30-19
Old Jan 20, 2018 | 12:06 PM
andrew e coupe's Avatar
2017 E400 Coupe & 2018 GLC43
I'm running a 245/35/19 front & 275/30/19 rear - conti dws tires as well. Also my car is lowered 1.4"
Old Feb 6, 2018 | 08:07 AM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
Id be more concerned about offset that tire size. Is the rim flush with the fender on the curb side or do yo have room for a spacer.
Old May 26, 2018 | 08:15 PM
pdeacon's Avatar
E450 wagon, C43 AMG Cpe, GLE AMG 63S
Sounds like you have an offset problem...not necessarily wheel size issue. If you don't have the correct offset you can correct the situation with wheel spacers based on your rubbing issue. Using spacers requires some calculation so don't rush into spacers without doing your homework. First step is to determine the offset of your AMG wheels and then look up your needs on some fitment charts that are available on wheel and tire websites or on this forum. Good luck and let us know how you make out.
