E200 Coupé 2011, Engine suddenly Stop
I write from Chile. I have dificults with my car and I hope someone knows the source of the problem so i can fix it.
I have an E200 Coupé manufactured in 2011 at the Sindelfingen plant, it has used only 50,000 kms., and I have always carried out the maintenance at the dealership (Kaufmann is the representative of the brand in Chile).
When the engine is running and the car is not moving (foot on the brake, like in the traffic light wating for the green light) and the gear selector is on the position “D” or “R”, the engine sudennly stop (it happens two or three times in ten). To explain better, is like in a car with mecanic gear box, when the car is not moving, engine running and de gear box is on the first gear position you remove your foot from the clutch without step on the gas, teh car jumps and the engine stops.
The big problem is that no light remains on in the dash board of the car, an no error is reported when the car is connected to an a Marcedes Benz scanner. Even a data package was sent to the factory and the answer was “theres is not failure”, but the problem remains... the car keep stoping.
Please sorry my bad english, is someone can help I’ll be very gratful.
Bye.
Here Some videos:
https://www.dropbox.com/s/xtbn7rqux3...Motor.mov?dl=0
https://www.dropbox.com/s/qdpnhylubj...20RPM.mov?dl=0
