Electronic damping bypass / canceler
Old Dec 6, 2018 | 01:39 AM
chmunter's Avatar
W207 - E 550
Lightbulb Electronic damping bypass / canceler
Hi there,
my car has the dynamic handling package and i had a new aftermarked sports coilover suspension installed. Now my car is stucked in Sport Mode.
It seemed that the problemfix is a cancellation kit for electronic damping system like from KW 68510305 or Eibach AM65-25-019-01-22. It look like some cheap resistors for very high price.
Had anybody another cheaper fix / mod for my problem?
Thanks for your answers
Old Feb 29, 2020 | 07:39 PM
mdm13588's Avatar
Past: 2005 C180, 2012 GLK350, 2014 ML350, 2015 C400 | Current: 2014 E550 Sedan & 2017 E550 Cabriolet
Originally Posted by chmunter
Hi there,
Did you get this problem solved? I have a 2017 E550 Cabriolet with dynamic handling package and want to lower the suspension.
Old Mar 23, 2020 | 11:28 AM
Mizarahi's Avatar
E250 CGI Cabriolet
Hi there,
Mine also stuck in sports mode. I just let it be. Doesnt seem to have any other effect except the button is lighted up.
Old Feb 3, 2022 | 08:41 AM
Thegingerone's Avatar
W204 C320cdi
Hi mate
did you ever overcome this issue? I’m going through exactly the same problem at the moment
Old Feb 3, 2022 | 01:47 PM
cszczech's Avatar
2013 E550 coupe
It sounds like you ma=y already know this, but it may be that the ECU is expecting to see a resistance from the shocks, if a low resistance can be found between 2 pins from the shocks, it may be possible to fool the ECU with a resistor. I have done this on my BMW track car for the passenger detector to enable the airbags.
Old Feb 4, 2022 | 03:45 AM
Trdspec86's Avatar
W204
It's able to solve this problem via coding.
I've done for a lot
But u'll need the proper tools to do it.
Old Feb 4, 2022 | 04:13 AM
W204 C320cdi
thanks for the reply buddy!
i assume software/hardware/diagnostic equipment etc
I don’t suppose you’re in the U.K. are you? 😂
Old Feb 4, 2022 | 11:02 PM
Trdspec86's Avatar
W204
I'm in singapore.
If u can find anyone that have vediamo engineering software n open port it'll be enough to do it.
Old Feb 8, 2022 | 02:19 PM
Dnasty's Avatar
2010 e550 coupe
I have a whole post about stuck in sport mode if you guys search it is on here. I ended up having to change a sensor at one of my shocks but others had different remedies.
Old Feb 10, 2022 | 09:49 AM
KSchluter227's Avatar
E 550 Coupe
KW makes a cancellation kit as well $420
Old Sep 19, 2022 | 07:37 AM
MrBiBi's Avatar
W207
Originally Posted by Trdspec86
I'm in singapore.
i want to do the coding
