How to Replace Window Switch
Old Jan 9, 2019 | 08:14 AM
JMBS's Avatar
C207 2009 E250 CDI
Hello guys,
Can you help me to find out how can I replace the passenger side window switch? Do i need to remove all the door panel? The switch hole is in the armrest and I do not know how to access it do release the screw.
Please see example image.
Thank you!! Regards.
Old Jan 15, 2019 | 02:37 PM
JMBS's Avatar
C207 2009 E250 CDI
Help please...
Old Jan 21, 2019 | 12:13 PM
konigstiger's Avatar
'71 Pinto
See attachments.
File Type: pdf
File Type: pdf
Old Jan 21, 2019 | 05:05 PM
JMBS's Avatar
C207 2009 E250 CDI
Thank you very much for the information. It is exactly what i was avoiding to do: disasemble all the door panel. Next weekend will work on that!
Regards!
Old Jan 22, 2019 | 02:56 PM
Rick-F's Avatar
2017 E400 C4 Coupe
[QUOTE=JMBS;7649626]
.[/QUOTE
To what screw are you referring?
Do you already have a NEW switch? Some switches simply can be removed by prying them up with a trim tool then pulling them out with your fingers-- if the electrical cable is long enough (and NOT all are), you can simply unplug the old switch and plug in the new one . . . I've done this on a Cadillac once. It would just take a moment to see if you are able to do it this way.
Good Luck.
Old Jan 22, 2019 | 03:08 PM
'71 Pinto
