Dynamic body control VS air body control
Hello everyone
I'm trying to found the differences between the two when it comes to lowering the car..
The manual says the (air body control) lowers the car 15mm depending on speed and you can do it manually too!
But what about the (dynamic body control) suspension?
Does it lower the car automatically when you change the dynamic select switch to sport plus for example?
Or this suspension system doesn't lower the car at all?
I looked every where but i didn't found clear explanation!
And ofcourse i can't check it on my car, because it didn't arrived yet.
Thinks in advance.
Thinks in advance.
Hey Guy,
Basically Air Body Control & Dynamic Body Control are completely difference. With Airmatic you can up & down your vehicle height because of air come in and out the air spring while Dynamic Body Control is steel suspension with electronic shock absorber control then there are only change in the hardness of suspension when Changing in Dynamic Select, not up & down the body
