Driver window rolls up then back down halfway.
Old Mar 19, 2019 | 01:15 PM
Dnasty's Avatar
2010 e550 coupe
Before anything I just want to say I did search this and tried every possible method available as far as reset goes.
My battery was completely drained the other day and for the most part everything worked fine except the windows had to be reset. I was able to reset everything but the drivers window which does something odd. It will roll all the way down but when I push the auto up it goes all the way up then opens halfway immediately after. I am not sure how to fix this without taking it back to the dealer.
Old Mar 19, 2019 | 07:43 PM
Cobra27's Avatar
2014 E550 Coupe, 2020 GLE 350 4matic
Try the window synchronization procedure in the attached. it worked for me on a rear window.
File Type: docx
Old Mar 19, 2019 | 11:21 PM
Dnasty's Avatar
2010 e550 coupe
For some reason the link doesn’t work. But I think I found the issue, for some reason the back window will not fully go up so it is throwing off the front window. After the front window is all the way up the back window should go up a notch and it isn’t doing that. I’ve tried resetting the back window but it doesn’t seem to be able to go all the way up. I only hear the two clicks when I roll down and not up.
Old Dec 21, 2020 | 03:15 PM
Cericw's Avatar
W213 E300
This worked perfectly 👌
Old Jul 20, 2024 | 07:44 PM
Fero's Avatar
2019 E 63 S AMG
This worked for me, thanks!
