E550 Coupe Panorama Sunroof Stuck Open
Old Apr 7, 2019 | 02:25 PM
mtempleton's Avatar
2011 E550 Coupe
I tried to open my 2011 E550 panorama sunroof and it stuck part way in the tilted position. Tried to manually move it using the the hex tool inserted in the motor, but although the motor rotates, no roof movement. I suspected the dreaded broken gear and ordered a new gear from eBay. Now the problem is how to get the left motor out. Looks like the entire headliner needs to be removed which is beyond my DIY capability. I would be satisfied if I could just get the pano closed as I rarely open it. BTW, the sunshade works fine.
Suggestions and input highly welcome, thanks.
Old Apr 7, 2019 | 05:23 PM
w3iRd's Avatar
W207
Hello, I had the same issue on my E350 and I removed the whole sunroof and cleaned it out , replaced it back and work perfect fast as never before n, otherwise the motor will be stucked and won't work anymore.
NB: you need a sunroof specialist or Glass technicien to remove it because it's bit hard to do it yourself ..
