Spark Plug Replacement
2014 E550 Cab
I'm being told that the issue with my 2014 E550 Cab is that the #3 spark plug has failed and it is misfiring. The garage claims that each spark plug takes 45 minutes to replace and the labour costs with diagnosis are $700 to replace every plug !!!
Can this be true? Do you think it is necessary to replace all spark plugs or just the one that failed at this time?
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
Received 1,600 Likes
Bu11 *****. Then the garage has no idea what they are doing. It does take a while, but even if your engine has two plugs per cylinder, it doesn’t take 45 minutes each. Go somewhere else or do it yourself. It’s not hard.
