Interior Replacement Parts
Old Apr 23, 2019 | 07:18 PM
Gailey's Avatar
2014 E350 4Matic
Looking for 2014 MB E350 4Matic Coupereplacement part source. I want to replace the plastic sliding cover for the rear seat cup holders with the wood version. Thank you!
Old Apr 24, 2019 | 11:04 AM
konigstiger's Avatar
'71 Pinto
2078400227 wood ash black
2078400327 burred walnut
See attachment, best to remove center cushion to access/replace cover.
File Type: pdf
Old Apr 25, 2019 | 08:32 AM
Mr. Toad's Avatar
2016 E400 Coupe (C207)
My car came with the cheap-looking plastic slider and I replaced it myself with a used walnut one that I found on eBay, taken from an e550. It's fairly easy to do, once you get the rear seat cushion out. Before you do anything else, pull up the rubber mat from the bottom of the cup holder space and remove the single screw that you'll find below it. Then, remove the entire back seat cushion (the center console will come out with it) and flip it over; the rest of the procedure should be pretty obvious. Installation is literally the reverse of removal.
