2011 E550 Convertible Top will not close properly
Is there a sensor for this last part that I might be able to check? The top retracts completely with no problem and it even closes and attaches to the visor area, its that final step of the back glass window that is not completing and retracting to the back rear deck! I hope I am describing this completely.
Labor Service - Convertible top inspection. Scanned and visual inspection. Found limit switch lever "flipped" over and not operating switch. This area has been tampered with before, as a couple of securing rivets were missing. Correct, clear fault data and test. Cost $135.00
Hope this helps you.
