Custom Wheels Help
Custom Wheels Help
Hi New to the forums. I have a 2014 E 350 Coupe and would like to purchase a set of Vertini Wheels to replace my stock wheels (18x8F & 18x8.5R). I wouldn't mind if they made a wheel with the same specs as my stock ones however, this is not the case. I do not want to degrade the handling not do I want to drop the car. Here are the sizes available. Can someone make a recommendation (or advise against) the best size to use if at all?
20X9.0 BLANK
20X10.5 BLANK
19X8.5 +32 5X112 66.56
19X9.5 +35 5X112 66.56
19X8.5 +35 5X114.3 73.1
19X9.5 +35 5X114.3 73.1
19X9.5 +40 5X114.3 73.1
19X8.5 +35 5X120 72.56
19X9.5 +35 5X120 72.56
Thanks in advance for all your kind attention and earliest reply.
These are the only ones listed with the correct bolt pattern and hub bore:
but I think 8.5 + 32 and 9.5 + 35 would stick out too much. If you can find some 5x112/66.56mm wheels with a little more offset (5-10mm more), they should fit well.
Charles Heim (08-13-2019)
