W207 E350 y94 quantity control valve fault code
Old Sep 18, 2019 | 05:17 AM
boonteo75's Avatar
W207 e350
Hi,
I have a w207 E350 petrol model.. Recently I encountered the engine light on. The symptoms includes loss of power, shaky engine and the car tends to halt when I pressed the pedal deeply.
The diagnostic machine came out with a '"y94 (quantity control valve)' has an electrical fault or an open circuit" fault code.
Is there any one have an idea of what's wrong with the car?
Old Sep 18, 2019 | 07:17 AM
speedlimit's Avatar
Administrator Emeritus
Hi!
Welcome to MBworld.
I moved your post the W212 forum. What year is your car?
Bob
Old Sep 18, 2019 | 02:31 PM
boonteo75's Avatar
W207 e350
Originally Posted by speedlimit
Hi!
Welcome to MBworld.
Bob
My car is a 2010 model
Old Sep 18, 2019 | 04:18 PM
konigstiger's Avatar
'71 Pinto
VIN?
Old Sep 19, 2019 | 05:01 AM
boonteo75's Avatar
W207 e350
VIN?
WDD2073572F053369
Old Sep 19, 2019 | 12:11 PM
'71 Pinto
I should note, not familiar with this engine. DIY (educated guess) check/replace 55, 165 in this order. Problem persists, could be pump 5. Definitive diagnose run “diagnostics” using MB Xentry. BTW you should be posting here: https://mbworld.org/forums/e-class-c...brio-a207-141/
File Type: pdf
File Type: pdf
Old Sep 19, 2019 | 02:54 PM
speedlimit's Avatar
Moved, thanks.
Bob
