ABS/ EBD/ ESP problems 🤦*♂️
Old Sep 19, 2019 | 09:04 PM
MBSCJ's Avatar
2011 MB C207 E350cdi blueefficiency sport
Hi guys,
first thread after ive had a nightmare with my 2011 E350 cdi coupe.
Went around a tight bend the other day (maybe a little fast) and ABS, ESP and EBD have been “inoperative” ever since. The faults have also rendered the runflat indicator inoperative, aswell as cruise control and ECO mode!
Have had the car on two two different diagnostics and both are showing it is the rear left ABS sensor (says signal implausible). Have fitted a new sensor to that wheel since this and tried to wipe the code twice, but it goes off and comes back on as soon as I start to drive.
Has anyone else experienced similar issues?
As I say I’m a newbie to this forum, and any help at all you can give me would be greatly appreciated as the lights on the dash are annoying to say the least!
thanks and kind regards,
Old Sep 20, 2019 | 02:02 PM
konigstiger's Avatar
'71 Pinto
Check left & right front @ steering knuckle, and rear @ wheel carrier rpm sensors/wiring (10 in diagrams).
Old Sep 23, 2019 | 03:26 PM
MBSCJ's Avatar
Sorry for the late response! And Thankyou for the reply all the same.
UPDATE: replaced sensor, no good. Rang the stealers and got a new impulse ring (abs pick up ring) for £15 all in...drive up the road and the faults cleared 😎
thanks again,
