AutoTalent | Renntech Performance Ecu + Brakes + Suspension For Mercedes-benz E 550
Golan@AutoTalent.com
Renntech Performance Ecu Upgrade
Click HERE to order Performance Ecu For E550!
Click HERE to order Performance Ecu For E550 Biturbo!
Click HERE to order Performance Ecu+
For E550 Biturbo
RennTech HHT (hand held tuner) allows you the unlimited ability to switch between tuned and stock ECU programming and requires no ECU removal. RennTech proprietary tuning module stores both the RennTech tuned file and your vehicles stock file. The module plugs directly into the OBD2 port and delivers the file you choose directly to the ECU. Programming takes only a few minutes and the vehicle can be reflashed at any time as many times as you wish. RennTech has been at the forefront of ECU tuning since electronic engine management started to show up in vehicles during the mid 1980's. RennTech experience, countless hours of in house research, development and exhaustive testing ensure that our proprietary ECU upgrade offers incredible performance gains and rock solid daily driver reliability.
Features
Long-lasting and driver reliability
Significant gains in horsepower
Increases the performance
Significant gains torque
Increasing the engine's rev limiter
Incredible performance gains
Renntech Performance Transmission Upgrade
Click HERE to order Performance Transmission Upgrade For E550!
Click HERE to order Performance Transmission Upgrade For E550 Biturbo!
RennTech transmission upgrade consists of a complete transmission disassembly and inspection as well as a mechanical upgrade to the transmission clutch packs. This allows us the ability to maximize the amount of friction materials contained within the transmission and in turn, the amount of power which can be transmitted through each forward gear. During final assembly the transmission also receives all new gaskets, seals, o-rings as well as a new transmission pan filter. RennTech Mercedes Transmissions increased engine performance it becomes necessary to further improve the drive line components, most importantly the transmission in order to ensure maximum power is transmitted to the drive wheels without transmission slippage. This can not be realized with software and only truly be accomplished by an internal mechanical upgrade to the transmission hardware. RennTech is the foremost authority on transmission upgrades and has done countless rebuild and upgrades for the most demanding dealers and clients for over 21 years. RennTech upgrade leads to improved shift response, shift timing, increased torque handling capabilities and greater drivability under extreme conditions without sacrificing around town comfort.
Features
Ability to maximize the amount of friction materials
Increased torque handling capabilities
Improves vehicles responsiveness
Increased engine performance
High quality material used
Improved shift response
Improved performance
Greater drivability
Shift timing
Renntech Exhaust Stainless Steel Sport Muffler
Click HERE to order Stainless Steel Sport Muffler For 550 Biturbo!
Click HERE to order Stainless Steel Header For 550!
RennTech stainless steel (SS) sport mufflers are hand made and rigorously tested to remove any unwanted resonances in the cabin to deliver a deep sound that keeps with the character of a luxury performance vehicle. RennTech Sport Mufflers are made out of T-304 stainless steel (SS) and 100% hand crafted in the USA. This exhaust system is rigorously tested to remove any unwanted resonances in the cabin to deliver a deep sound that keeps with the character of a luxury performance vehicle. RennTech mufflers with 2 3/4 inch diameter tubing offer lighter weight than the stock exhaust and improve performance by reducing exhaust back pressure, increasing exhaust gas flow and cylinder scavenging.
Features
Improve performance by reducing exhaust back pressure
Lighter weight than the stock exhaust
Stainless steel (SS) sport mufflers
Improving exhaust gas flow
Renntech Performance Brake
Click HERE to order Renntech Performance Brake Package 1 For E 550!
Click HERE to order Renntech Performance Brake Package 1 For E 550 Biturbo!
RennTech understands that brakes are one of the most important components of any performance car. Big brake upgrades are some of the most capable systems available at any price. Designed specifically to complement and control the mass of high-performance Mercedes and AMG cars, RennTech's big brake packages deliver consistent, real-world performance and look great behind your performance wheels. RennTech basic brake upgrade uses braided steel lines (front and rear) and high-performance brake pads (front) to deliver more consistent brake pedal feel and reduce fade compared to stock. RennTech philosophy has always been to produce products without compromise.
Features
RennTech performance eight (8) piston front brake calipers
Deliver more consistent brake pedal feel
Reduce fade compared to stock
High-performance brake pads
Long-lasting reliability
Renntech Performance Package
Click HERE to order Renntech R1 Performance Package For E 550!
The RennTech R1 Performance Package is the perfect entry level performance upgrade for the E 550. The R1 performance package for the Mercedes 550 includes our proprietary ECU upgrade in addition of stainless steel shorty headers designed specifically for the 550 V8 for a combination that provides increased performance, sound and throttle response across the vehicles entire powerband. The addition of this helps the engine to perform well and better. The R1 performance package for the Mercedes E550 engines includes proprietary ECU upgrade, in addition of proprietary stainless steel shorty headers, this combination that provides huge increases in horsepower, torque and throttle response across the vehicles entire powerband while still maintaining daily driver reliability.
Features
Gains up to +38HP & +30TQ
Increases horsepower
Increases throttle response
RennTech ECU Upgrade
Stainless Steel Shorty Headers
Stock Performance
382 Hp @ 6000 Rpm; 391 Lb-ft @ 2800-4800 Rpm
Modified Performance
420 Hp @ 6000 Rpm; 421 Lb-ft @ 2800 Rpm
Renntech Suspension Coil Over
Click HERE to order Suspension Coil Over For E 550!
Click HERE to order Suspension Coil Over For E 550 Biturbo!
The new V3 Coil Over Suspension is state-of-the-art technology with adjustable compression & rebound dampening for the skilled drivers. The separate and independent compression and rebound damping options allow for a truly individual driving set-up. These unique systems with the 3 individually adjustable components, allows for adjustment of the compression of the damper in the low-speed-range, while the high speed set-up has been pre set.
Features
Independently adjustable damping technology - rebound and compression damping
Stainless steel lines
Individual height adjustment
TÜV-tested adjustment parameters
High quality components for long life
Comprehensive documentation for ease of use
Front: 1.2"-2.3"
Rear: 1.0"-2.2"
How to Place Your Order:
Phone Domestic: (855) 973-2757 X 104
Phone International: (310) 231-7800 X 104
E-mail: online@autotalent.com
Website: www.AutoTalent.com
Payment:
Attachment 439933
Installations:
Feel free to visit us at our facility in Los Angeles, CA.
We install everything we sell.
19143 S. Hamilton Ave
Gardena, CA 90248
Shipping:
All orders are shipped via FedEx, UPS, USPS and Pilot.
International, Hawaii and Alaska customers: Please contact us for the best quote possible.
Hours of Operation:
Monday through Friday: 10AM-7PM Pacific Time
Saturday: By appointment only
