E350 holding onto gears longer
Its always when the car is up to temp, sometimes when I've been driving enthusiastically. something tells me it may be temperature related somwhere, but no idea where
step 1, sit in the car, turn on the ignition so dashboard lights up (do not start the car)
step 2, press and hold the gas pedal to the floor for a minimum of 10 seconds
step3, switch off the ignition, remove foot from gas pedal, do not remove the key
step 4, wait for minimum of 2 minutes, do not open door or leave the car.
Step 5, go for a 15 minute drive at your typical driving pace/manner, make sure you vary accelerations and braking etc, avoid driving at a constant speed. the transmission will then adapt to your driving manner.
Step 6, drive home and make cup of tea.
