Driver Door Window Loose?
Old Feb 5, 2020 | 04:05 AM
Davery's Avatar
2012 E550 Cabriolet 2011 VW Eos 1985 Pininfarina Spider
My driver's side door window on my cab is making a strange rattle. I've noticed sometimes the window drop prior to opening the door is slow. I'm wondering if the door is being opened before the window drop occurs and has damaged some inner door window guide or something. Anyone else have this issue?
Old Jun 14, 2020 | 10:57 PM
pimpingml350's Avatar
2012 ml 350 bluetec
Did you find the problem ?i am having the same issue , going to pull off the door panel and take a better look .
Old Jun 17, 2020 | 07:35 PM
Davery's Avatar
I have not had a chance to work on this. I'm hoping to get to it in a few weeks. Let me know what you find out.
Old Jun 18, 2020 | 12:42 PM
konigstiger's Avatar
'71 Pinto
See attachments.
File Type: pdf
File Type: pdf
Old Jun 19, 2020 | 12:11 PM
2012 ml 350 bluetec
just fixed mine same problem. the screw that holds the window was loose. took it out , put some locktite on it , good to go. 20min tops to fix
Old Oct 4, 2020 | 03:43 AM
Kwarior's Avatar
W221 S Class
The control module in the door needed flashing. A quick and cheap repair.
Old Aug 8, 2022 | 04:00 PM
bill_097's Avatar
C207 - 2011 E550 Coupe
Hi there,
Which screw are you referring to? Would you happen to recall and is it in one of the above attached PDF docs?
