Water from rear drain holes when parked on hill
Eclass 350 convertible A207 2011
Hello all
im new to this so apologies if I’ve posted in wrong place !! I parked my car on a slight hill today facing up and noticed that water was coming out of the rear drain holes in either side .. my question is Are there any froNt drain holes ? I’m thinking perhaps if so then these front Holes are blocked and therefore due to being on the hill the water was forced to the back ? Anyone else have this issue ? Any advice would be appreciated..
You're in the correct forum. Drainage is addressed here, see attachment if you decide to remove panel: https://mbworld.org/forums/e-class-coupe-c207-cabrio-a207/529094-heads-up-cabriolet.html
Laurence50 (06-28-2020)
Hi, I just wanted to update for anyone else having the same issue as it seems to be a common fault on the e class convertible.. Now the fix for me was to take out all four plugs which are located at the jack points under the car , unfortunately they just span when i tried to remove therefore i added a small screw into them & simply pulled them out.. Now i decided to add them back in rather that leave them and before i did this i drilled holes through the plugs themselves .. This has giving me a solution to the problem and easy to unblock.
