Rear View Camera Issue
Old Nov 17, 2020 | 08:34 PM
Davery's Avatar
2012 E550 Cabriolet 2011 VW Eos 1985 Pininfarina Spider
A couple of weeks ago I noticed my rear view camera did not work a couple of mornings when I started the car. Later in the day it started working. Last week the rear view camera stopped working entirely. No 'check your surroundings', just a black screen. I originally thought is was the camera and I installed a used OEM camera. I was told it worked, but I it is not working for me. Again, no 'check your surroundings', just a black screen. Would another OEM camera need to be programmed? Is there a setting in the engineering mode I should check? Does this sound like a rear view camera module? Thanks!
Old Nov 19, 2020 | 09:36 AM
Mr. Toad's Avatar
2016 E400 Coupe (C207)
This may sound like a stupid question, but is the COMAND screen turned on? If the screen is not on, the camera view will not be displayed when you put the car in reverse; you'll still get just a black screen.
Old Nov 19, 2020 | 03:50 PM
Davery's Avatar
Not stupid. The nav is working until I put the car in reverse and then the screen goes blank. I can see something happening when it should be switching to the rear view camera. It looks like there is some sort of signal, just a black screen.
Old Nov 20, 2020 | 06:18 AM
Harold1898's Avatar
2015 E400 Coupe
Ask the dealer to diagnose it for you. They will usually do this free of charge hoping to get the business. I imagine they will just plug into the diagnostic port and have the answer immediately. Electronics are never cheap on a Benz. Good luck with the fix.
Old Nov 20, 2020 | 04:13 PM
Davery's Avatar
Not any dealer near me. They want $166 to diagnose the3 issue.
Old Dec 1, 2020 | 12:19 PM
konigstiger's Avatar
'71 Pinto
May need to be re-calibrated, see attachments.
