reverse lights
E Class C207
reverse lights
Hi, I've just installed Android HU and I need to connect a reverse camera, my questions are
1. How do I get access to the tail light wiring?
2. which color wiring is for the reverse light?
any diagram, video, or link will be very much appreciated Thanks
the vehicle is C207 2012.
If you are using the stock OEM camera, you don't need to tap into any wiring. You must have missed a step when installing/wiring up the unit. The cable from the rear camera plugs into the MB command head unit. The cables that connect the android screen to the MB command unit, should capture the video signal from the rear camera & reverse engagement to activate it.
