Are the factory rear brake rotors drilled?
Looking at replacing the brakes all the way around so that I know for certain the work is done correctly and so that I can verify the quality of the parts.
With that being said, the rear rotors on yhe car are regular and I do not see drilled rear rotors when searching online for the coupe. I see drilled and slotted, but not just drilled. I thought the car had drilled rotors both front and rear.
What is the case on the rear rotors? Did they come from the factory drilled? If so, any suggestions on a good brand? I noticed that the sedan has more rear rotor options than the coupe.
qdeezie (01-16-2021)
qdeezie (01-17-2021)
