A207 2010 E350 Drainage Channels - Wet Rear Footwell
I have purchased a 2010 E350 (A207) a week back and noticed a wet rear footwell a day after I got the car...I vacumed the water out and used a heater - dehumidifier to dry out the wet carpet painstakingly squeeezing out as much water from the sound deadening as possible....last night it rained and I noticed today that the rear footwell behind passenger seat is wet again....I dont see any evidence of water seeping through window glass seals/roof lining....reading this forum i suspect its blocked drains...
I have not idea where all the drains on this model are located and which ones would be prime suspects for water to end up behind the passenger seat....Any one has a diagram of where all drain channels are and any guidance on how to flush /unblock them.
Thanks in Advance!! (scared of driving the car as I dont want to mess up any electronics)
Hey I may have an idea I fixed my e550 coupe. Please email me nickdigi7@yahoo.com
Hey I may have an idea I fixed my e550 coupe. Please email me nickdigi7 at yahoo dot com
have you figure out why there was water in having same issue now I pulled apart everything and can’t get it to leak when I put a hose to it
From what I've read it's a possible sunroof drain that's compromised, either plugged or cracked.
I've opened the sunroof, but I don't see any drain holes???
I don't remember the rear holes, maybe because they were too difficult to see? It's just be too long and I don't recall if I tried to see them or not.
Please take pictures and share the process to help others when you're done
Someone may have already done just that and pix might b somewhere on this forum, or someone online.Meanwhile, and to check if it's the roof or not, I'd tape up the sunroof. I'd also consider pulling up the carpet to dry it because it's likely still wet in there. Plus you can check if anything important got wet, before it fries. These cars have way too many plugs and electronic "things" in there, and all expensive.
Best of luck to you!
