A207 tow away sensor
Old Jul 6, 2021 | 06:25 PM
sloper's Avatar
A207 E 220d Convertible
Hi ...does anyone happen to know the location of the tow away sensor in an e class a207 convertible...got a malfunction on diagnostics ...I can't see it on boot area am wondering if under transmission tunnel console before I go digging? Thanks
Old Jul 7, 2021 | 04:39 AM
sloper's Avatar
tow away sensor
cant open this for some reason...would you believe that MG main Dealer don't know where this sensor is located in convertible.. their diagrams show it in the middle of roof!!!
Old Jul 13, 2021 | 04:32 PM
konigstiger's Avatar
'71 Pinto
N26/13 (master) check behind door panel try DCM access first before removing entire panel. N26/15 (slave) looks as though it is located under rear seat cushion. See attachments.
File Type: pdf
File Type: pdf
File Type: pdf
Old Jul 15, 2021 | 05:04 AM
sloper's Avatar
tow away sensor
Brilliant..many thanks thanks konigstiger...much appreciated ...am on holiday at the moment but will check this out on return 👍
