W207 Trunk switch replacement
Old Jul 31, 2021 | 05:53 AM
adsport's Avatar
W207 E220
Hi! I have a W207 2015 model and need to replace the button to open the trunk. I haven't been able to find any guide on how to do it so I was wondering if someone could help guide me through the process of dismantling whatever's needed to replace the switch. Thanks!
Old Jul 31, 2021 | 11:09 AM
konigstiger's Avatar
'71 Pinto
Replacing complete switch assembly, carefully pry up & out preferably using plastic wedge. Button only, if you find stand-alone button (window shown, same method):
Old Jul 31, 2021 | 12:04 PM
adsport's Avatar
W207 E220
Thanks for your reply! I should have explained properly that the switch that needs replacing is the one on the exterior at the back of the car next to the license plate lights.
Old Jul 31, 2021 | 03:47 PM
'71 Pinto
See if attachment helps to gain access. Need VIN to supply replacement part #.
File Type: pdf
Old Aug 1, 2021 | 03:03 AM
adsport's Avatar
W207 E220
Thanks! This is exactly what I needed.
