2011 E350 Cabriolet Electronics not working after battery replacement
Hi All,
I am experiencing an electronic issue after replacing my original battery. Battery finally died, I replaced it with a new AGM Battery (Excide) same specs as the original Varta battery. The issue I am having is that my driver side seat is not functioning, the side mirrors are not working, the drivers memory seat function is not functioning, all 4 window switches do not work on drivers side.
The center console switch that controls the rag top and windows function properly. All windows will go up and down. The passenger window switch is working.
Everything was functioning prior to the battery dying.
iIs there an auxiliary battery installed in this vehicle?
or is there something else I should be looking at?
Thanks in advance!
Thanks in advance!
