Power steering hose
Power steering hose
Greetings,
I had problems with a buzzing sound from the front axle which turned out to be a leaking hose. My mechanic says that mercedes has expensive parts so replacing it should not be an option, instead an attempt to be fixed will be made. I still would like to try replacing it so i ask you where do you find replacement parts for your cars. I tried autodoc.co but for my car the part is not available. If anyone has had this problem, how much have you paid. I'm european.
Received 4,435 Likes
'71 Pinto
You can try: https://www.fcpeuro.com/ provide VIN if you want line diagram w/part #s.
