Seatbelt retraction
Old Apr 4, 2022 | 08:31 AM
PaulTee's Avatar
A207 E250
Seatbelt retraction
2015 A207 - the seatbelt on the drivers side is very sloooooooooooow to retract. Anyone had this problem and solved it, rather than buy a new belt?
Old Apr 4, 2022 | 09:54 AM
konigstiger's Avatar
'71 Pinto
See attachments to check.
File Type: pdf
File Type: pdf
Old Apr 5, 2022 | 12:37 AM
PaulTee's Avatar
A207 E250
Thanks for the reply but it is the actual belt that is very very slow to retract and not the extender, that works as it should.
Old Apr 5, 2022 | 12:22 PM
WRC-LVR's Avatar
2012 E350 Cabriolet now SOLD to my son
Pull the belt out as far as you can, then soak the belt w hot water and dish soap. Use micro fiber towels to dry off , squeezing the belt firmly with the cloths. Redo the wash and dry step , paying extra attention to getting the belt very dry ; then let the belt dry fully extended.
Belt picks up body oils and dirt becoming stiffer over time. This will fix it
Old Apr 5, 2022 | 01:37 PM
'71 Pinto
Here's bulletin as discussed although your vehicle is not within production range same corrective procedure should apply.
File Type: pdf
