Pneumatic Pump keep on running
Workshop already scan and no fault codes being found, anyone have this issue before?
any advices would be highly appreciated
Seems to me the dials would be potentiometers which typically don't last long and do not like fod getting in them, like dust and what not.
So I suppose my first experiment would be turning all dials down to off, then turn each up full blast one at a time to see how how they fill up, then deflate for a few cycles. See if they get nice n tight like they're supposed to, and listen to see if at any time during testing them if the pump turns off, even for a split second. I'd also turn all of them up full blast together because if one bag is leaking into another then it'll run unless both are supposed to have the same pressure. If not then the one with the higher setting will pump in to the one with the lower setting and the lower one will be venting air because it's higher than its setting, so it pumps and vents forever. If so, then setting all to full blast should mean no venting and they all fill up and pump turns off. Worth a try.
