Multi-contour seats - testing
Before I dig in to replace the pump, I want to test the seat to ensure the bladders are all functional and didn't cause the pump to burn out because they are leaking.
I checked the main air connector under the seat that goes to the control valve and they aren't broken. I want to disconnect it there and apply air to the control valve to test the seat bladders. My question is, how many psi should I use?
Thanks!
thanks much!
