Window Opportunity
Old Nov 2, 2022 | 07:30 AM
Snarla's Avatar
Mercedes e350 coupe
Window Opportunity
Hello friends.
A couple of questions regarding the rear side windows on my c207.
When I open the door, all 4 side windows lower slightly. After closing the door, the front windows raise into the closed position...but the back two don't always do the same. I have to use the rear power window button to fully close the rear windows. Is this correctible?
Lastly, should the rear side windows have a one touch up feature on the power window button??. They do have a one touch down.
I'm very much enjoying this car.
Best,
Mark
Old Nov 2, 2022 | 12:44 PM
Siegmann's Avatar
10-second E550
Originally Posted by Snarla
Hello friends.
Best,
Mark
Turn the key to "on", raise the rear windows and continue to pull up on the control for a few seconds until you hear a faint click. This resets the fully closed position.
Like yours, my rear windows will one-touch lower, but not raise without holding the control. Kind of annoying, not sure if normal.
Old Nov 2, 2022 | 01:02 PM
Snarla's Avatar
Mercedes e350 coupe
Many thanks Siegmann!
But my car has a push button to start. I can remove the button ( I learned) and insert a key..and turn it to the on position?
I shall try.
Much appreciated.
Old Nov 2, 2022 | 01:09 PM
Siegmann's Avatar
10-second E550
I shall try.
Much appreciated.
You can also push the button once without your foot on the brake.
Old Nov 2, 2022 | 03:18 PM
Snarla's Avatar
Mercedes e350 coupe
I shall!!
This forum is very helpful.
Thank you!
