Jerky binding when backing out of driveway on cold start
Old May 3, 2023 | 02:20 PM
EyckVanDyke's Avatar
2012 E550 Coupe
Question Jerky binding when backing out of driveway on cold start
Hi all, I just bought a 2012 E550 coupe with 31k miles on it 1 owner, and everything is in pristine condition and it runs really smoothly with the exception of when I'm reversing out of my driveway on a cold start.
When backing out, it moves smoothly until I start turning the wheel sharply, and I drop off the little bump separating my driveway from the street. I'm not sure if it's the sharp wheel turning or the bump, but once I get halfway out, something starts binding periodically and making popping sounds, and the car moves rather jerkily. I've checked and there is plenty of undercarriage ground clearance, and once I'm back in Drive and going forward everything is fine, even if i make sharp turns or go over bumps. No noise whatsoever.
Once it's warmed up, I can't seem to replicate the issue either.
I've seen some mixed advice on similar issues, such as this thread, but I wanted to ask if anyone else has experienced this on a RWD MB, and whether or not I should be concerned. I'm taking it back to the dealer soon but also wanted some more opinions.
Thanks in advance!
Old May 3, 2023 | 03:05 PM
PeterUbers's Avatar
Thanks in advance!
do you have all summer tires on it? If so it could be wheel hop that is common when tires are colder than 40F
Old May 3, 2023 | 11:07 PM
2012 E550 Coupe
Thanks for the reply. I just checked, yes they are summer tires indeed. I also verified that it's not the bump that causes it, and it also happens in forward too. So it's just cold start + sharp turn = something binding or skipping.
Old May 3, 2023 | 11:17 PM
PeterUbers's Avatar
how cold is it outside when this happens? This sounds like tire hop
https://mbworld.org/forums/c63-c63s-...s-jumping.html
Old May 18, 2023 | 07:14 PM
Hee-Haw's Avatar
2014 E350/C207
Do you service the differential?
Old Jun 14, 2023 | 11:15 PM
2012 E550 Coupe
Fixed!
Hi and thanks for the reply! the tires were quite rotted and old, I think they were the original summer tires that shipped with the car in 2012, I put new conti's on it and no more binding/skipping feeling on cold starts now!
