When does brake pad wear indicator usually come on? on when
Hi, 2012 E350 Coupe, base, no 4matic. Just trying to learn about brake wear, when to change the pad, should I wait for the warning light or should I go ahead with visual inspection.
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Received 3,934 Likes
2017 GLE350 4MATIC
Wear indicator turns on with approx 2.5mm pad thickness remaining. New pads are in the range of approx 10mm-12mm thick, depends on brand/model.
SPONSOR
11 E550, 16 AMG GTS, 13 S550
Different pads have different depths for the sensor mounting point as well as OEM/aftermarket pads having different thicknesses and different shims. Some use steel, some use rubberized steel, different thicknesses, etc. It's usually 25-30% in my experience. Porsche/Audi are the same way.
You will notice the noise and brake fade long before the sensor hits, few people with mechanical empathy let it get that bad. My rule of thumb at the shop is when the pad gets to about the thickness of the backing plate, you should consider brake service soon. It's the easiest check. Always replace rotors with the pads, and consider high quality ceramic pad replacements if you want to extend rotor and pad life as well as pedal feel.
Use a high quality high carbon brake rotor, Brembo, Pagid, ATE, MB Genuine is actually pretty cheap on some applications, Zimmerman. Sensors should be Pagid or BOWA. Fluid should be done every 2 years, less if you drive fast. Clean lubricate everything, OEM pads produce a ton of dust. If you can buy new brake hardware, please. It'll prevent the pads shifting around in the caliper, producing annoying clicking noises.
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Service Manager/Owner
Amsoil Independent Dealer #7236674
chassis (06-25-2023)
SPONSOR
![](https://cimg2.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1333/image_d0909a378175e62af84bb18a83b0ab617073a949.png)
![](https://cimg0.ibsrv.net/gimg/www.mbworld.org-vbulletin/1500x1499/image_8d8e5fbfd23be988019b6afe3575dac2d8063be9.png)
The physics behind what make German cars so good is pretty fascinating. Your average chinese-made Pagid rotor goes through way more testing (has to be ECE-R90 and TUV approved) and service than your average Toyota part while costing less money, and being installed on much faster cars.
__________________
The following 2 users liked this post by mpalsal:
chassis (06-25-2023),
ChrisHimself (06-25-2023)
