Panoramic sunroof drains
Old Aug 18, 2023 | 12:19 AM
RosSauce's Avatar
2012 C207 E550 RWD
Anyone know where the drains are on the panoramic sunroof? All the videos online show obvious drain holes on sunroofs from other models (I couldn’t find any for the C207). Mine is probably clogged since I noticed some water staining along the bottom sides of my inside roof liner around where the clothes hangers sit. I tried fishing around the roof with yard trim line to no avail. I also noticed each side of my sunroof seal has 1 small slit, could this be a crack and letting water in?
Old Dec 18, 2023 | 06:57 PM
CleanMerc's Avatar
2010 e350 coupe
Any luck finding the drains or fixing the leak having same issues and every fix is for w212 version and not the coupe
Old Mar 21, 2024 | 09:32 AM
Artemis63's Avatar
2018 E63 S Wagon
did you find the drain holes? I have a W213 E class that looks just like your picture. i even removed the windscreen but the drain holes are not visible. i am wondering what else i need to remove to access them.
Old Mar 21, 2024 | 11:05 AM
wheatswake's Avatar
2017 S550 coupe, 2013 E550 coupe, 2008 Tahoe
My 2013 E550 coupe C207 does not have drains like the sedans do. The drain channels are actually part of the roof. I removed the pop in strips running along the panoramic panels on both sides to confirm while i was greasing the sunroof to slide better.
