Need help: how to remove this trim?
Old Sep 4, 2023 | 04:12 AM
MYMozz's Avatar
C207 E250 CGI
2012 C207.
Getting a buzz while driving from this trim. I know it is this piece because noise stops when I place my hand on it.
want to remove and put some felt tape, hopefully getting rid of the buzz.
Anyone has experience and can help with how to remove it?
Thanks in advance.
Photos is removed part from the internet.
Old Sep 30, 2023 | 12:19 AM
Nbxjskamg's Avatar
E63amg
You habe to remove the center grill first, in order to remove the sides.
the passenger side grill needs to slide towards the driver side, before being pulled out.
Old Sep 30, 2023 | 12:28 AM
MYMozz's Avatar
C207 E250 CGI
Thank you so much. Does the center grille just pop off when you pry?
Or is there any special way to remove it. Thanks again
Old Oct 1, 2023 | 01:01 AM
RosSauce's Avatar
2012 C207 E550 RWD
I used plastic pry tools to remove the middle speaker cover and then for the side ones I think you have to slide them toward the middle then with a little work then can pull up and out. I broke a few clips so be careful. I used some felt tape around a few of the speaker cover prongs which fixed the dash rattle I had.
