AC/Heater not blowing air
New issue I need some help with.
The AC/Heater is not blowing at all. I replaced the resistor hoping that was the problem. But when I turn on heat or AC, no fan movements on either. I did check the fuse.
do I need to replace the blower motor section?
thank you
thank you
I did replace the resistor. I also took out and checked the blower motor. I’ll try to attach the video. That seemed to work fine.
fuse was good too. Any idea on which relay goes to the blower? None are marked but I think it’s K17.
