E-Brake will not release
Old Apr 2, 2024 | 11:14 AM
ajgonzalez563's Avatar
2012 E350 Cabriolet
Question E-Brake will not release
My A207 E-Brake will not release regularly. This is a recent development. It functions, meaning when fully depressed the brake light is on and the brake is engaged. When i pull the release handle it will not release, sometimes there is a delay but others i need to physically assist by pushing/pulling up on the pedal. There are no codes so it seems a mechanical issue. Has anyone had anything like this happen? With no codes i would hate to have a service tech dig around at $$$$/hr. Any ideas would be appreciated.
Old Apr 2, 2024 | 11:34 AM
The_Judge's Avatar
2018 E400 Coupe
I've occasionally had a similar problem with my 2018 E400, usually after a trip through the carwash. Issue seems to be related to the brake pads sticking to the brake discs, perhaps due to a bit of rust (we live near the ocean, and the salt air affects everything). The brakes release after a few back and forths. Dealer said to be sure to dry the brakes after any wash. Hasn't happened recently, so perhaps it's more of a problem when the brakes are new.
Old Apr 8, 2024 | 01:13 PM
escarolo's Avatar
Hello from Spain.
I had the same issue and is so easy to fix that you will not believe it.
You just need WD40 or similar and 5 minutes
Now it works soft and fast as brand new
Old Mar 5, 2026 | 12:57 PM
Beachmark9@gmai's Avatar
2016 E 400 Cabriolet
Originally Posted by escarolo
Hello from Spain.
https://www.youtube.com/watch?v=WZNm...S01dA4&index=5
My A207 E 400 cab does the same. Ill try. Ty
