No crank and no communication with obd2
I've recharged the battery (duralast platinum dated 10/23) at autzone and had them test it, nothing wrong with it.
Checked all fuses in both the front and rear SAM and they are all fine.
I looked for the infamous auxillary battery but turns out my car model doesnt have it i guess. I've checked behind the side panel under driver dash (theres only 2 fuses in there) and in the trunk next to the spare tire. No battery to be found and I'm not sure where else it could be.
I've explained these symptoms to close mechanic friends and they've both said it's most likely the ECU getting cooked from letting it idle in the heat for so long.
Just looking for any other opinions or advice on other things to check. Im decently mechanically inclined but I start getting lost when it comes to these kinds of electrical problems.
Edit: forgot to mention, i didnt unplug anything when i did the knob shaft repair since the car was running. I was careful to not pull on any wires so I'm positive it can't be something I did during the repair. I even tested the scroll function before reinstalling the module shortly before the car started experiencing all the issues - everything was working as intended. The issues happened between the time I tested the scroll wheel and reinstalled the module and interior trimmings.
if no scanner can communicate via the OBD2 port, the next step go old-school.
Key IN, cluster lit? Sound of steering lock motor?
Key turns?
Check voltages at the starter relay. If OK
Jump the relay with FUSED wire, if the car starts -> there is a logic control problem.
It can be theft protection, or damaged module > more diagnosis
