Causes of vibration through steering wheel and floor of car/gas pedal?
Old Oct 15, 2024 | 12:19 AM
RosSauce's Avatar
2012 C207 E550 RWD
I had to replace my shocks/struts after about 140K miles due to them leaking and ended up going with coilovers and then H&R lowering springs with stock replacement Monroe shocks. For some reason the ride is pretty rough, mainly on small bumps, surface level changes, and road imperfections. It feels like it crashes and bangs over them while larger bumps or dips are fine. There's also minor but noticeable vibration at almost any speed in my steering wheel and through the floor/gas pedal of the car. I've changed all of the following which did not help and I'm at a loss for what else to check:
  • Front control arms complete with new ball joints/bushings.
  • Front and rear shock top mounts, bearings, spring retainers, etc.
  • New wheels, tires, balancing, alignment.
  • New front sway bar, new adjustable sway bar end links in the front and rear installed on the ground with zero pre-load on the sway bars.
  • New hub and wheel bearings for front driver and passenger sides (used dial indicator to set play according to Mercedes spec).
  • Brand new Monroe (OEM maker of our shocks) front and rear shocks.
  • Checked and re-checked and re-checked torque values on all shock/strut bolts.
The only things I can think of would be the rear control arms or subframe bushings going bad? I had to unbolt the rear control arm leaf spring where it attaches to the subframe to install the rear springs and forgot to torque it under load and drove that way for several thousand miles but have since corrected it. It looks like the subframe bushing here might be leaking though. I also have some play when I shake the front wheels up at down while the car is up on jack stands. It only happens at 12 o'clock and 6 o'clock positions and not other positions which points to the hub/bearing assembly but I re-checked the bearing play several times and it was within spec. I also hear what sounds like excessive tire noise from the front but could be the bearings? Any ideas?
Old Oct 15, 2024 | 01:06 PM
ibbij's Avatar
Bi-Turbo E550 Coupe (W207)
Have you checked your engine mounts? Those are known to go out after 5-7 years.
Old Oct 16, 2024 | 12:36 AM
RosSauce's Avatar
2012 C207 E550 RWD
Yup changed those and the transmission mounts. Also a weird thing that makes me think I'm crazy: some days my suspension rides smooth and other day it rides really rough, even in the same non-sport mode. I ran over the same bumps and areas over the past few days and it was crashy yesterday but soft today. No idea what is going on.
Old Oct 16, 2024 | 02:22 AM
ibbij's Avatar
I wonderful if it’s because of the lowering springs. If you had OE spring I wonder if it would help.
Old Oct 16, 2024 | 02:24 AM
ibbij's Avatar
https://www.shocksurplus.com/blogs/s...doomed-romance
Old Oct 17, 2024 | 12:30 AM
RosSauce's Avatar
2012 C207 E550 RWD
Thanks! I'm planning to put my stock springs back on but used brand new shocks with the H&R springs. I had similar crashy ride issues with two different coilovers, one of them being highly regarded Bilstein B16 PSS10s. Right now I'm thinking there could be an issue with my wheel bearing and knuckle since I think I'm hearing some whine from it but originally thought it was noisy tires. I might have messed up the install or have a bad knuckle since there is still play in the hub even after putting on new wheel bearings. I also noticed the driver side hub spins more freely than the passenger side (checked it with my brake calipers taken off and also made sure the bearing play was correct on both sides). My car keeps pulling to the right, even after several wheel/tire swaps and alignments so this might make sense with bad bearings?
