I can not locate all 4 CPS units, please help
Old May 2, 2025 | 12:01 PM
Mjnfl's Avatar
2012 E350 Convertible
Hi guys,
So it seems pretty clear after reading so many post here that there are FOUR CPs units on my 276.9** Engine. I thought there were only TWO after recently removing the intake manifold.
The two I saw were right up front and obvious as could be, I kinda new that must have been too good to be true! But I have tried find the other two which I am assuming are located in the rear
and I am not having any luck. Does anyone have a link to a video perhaps that shows the location of all the sensors or at least the rear two?
I had already purchased replacements for the front units but I had not installed them yet. Then this morning I removed the ECU to look for signs of a water leak and as soon as I unplugged the ECU I saw
a small amount of oil in the socket, so now I am worried. I want to go ahead and do this repair soon.
As always thanks in advance for any help/ info.
Old May 2, 2025 | 12:08 PM
chassis's Avatar
2017 GLE350 4MATIC
Originally Posted by Mjnfl
Hi guys,
If you found two, the other two are in the same place on the other side of the engine, or a few cm/inches away from the two that you found.
Please post a photo of the two that you found.
Old May 2, 2025 | 03:53 PM
Mjnfl's Avatar
Here is a photo of the 2 I found so far
Old May 2, 2025 | 03:55 PM
Mjnfl's Avatar
Hi Chassis, thanks for responding. I have uploaded a snapshot. Hope this helps.
Old May 3, 2025 | 08:15 AM
Mjnfl's Avatar
UPDATE 2:
So after taking another closer look and knowing where to look I did indeed find the other CPS units and I am ready to tackle the change out as soon as I get the new parts.
Thanks again!
