E-Class Coupe (C238) & Cabrio (A238) 2017 - E200, E220, E300, E350, E400, E450 [Coupes &Cabriolets]
AC fan speed stronger when top up vs. down
Old May 25, 2019 | 12:32 PM
jimzbenz1's Avatar
2018 E400 Cabriolet
When my A/C is set on auto with the top down, and then I raise the top, the fan speed of the a/c increases considerably. It would make more sense (to me) for the a/c fan speed, if it was different with the top up vs. down, to be higher with the top down than up. I want/need more cool air when the top is down and there's no shade, compared to when the top is up.
My dealer states that this operation is "normal operation", that "the blower motor of the a/c will never be able to overcome the outside temperature, therefore the a/c system reduces the blower speed to increase efficiency of the overall vehicle."
Can anyone confirm that this is in fact normal operation? My convertible audi was the exact opposite, higher fan speed with the top down.
Thanks!
Old Jun 3, 2019 | 11:12 AM
DFW_Neal's Avatar
2015 S550 ordered
I’ve been noticing this as well but I like the way it works. My last convertible was an Audi S5 and I was living in Texas so I like the A/C blasting if I was going to drive top down on the hottest days. (I usually just left the top up which defeated the purpose.) But now I’m in Utah where top down weather is great. So having the fan go down when I lowered the top is just fine. Mostly I just turn the climate control off when I’m driving top down here.
But answer your question - my E53 operates the same as yours.
Old Jun 3, 2019 | 02:06 PM
happyinboca's Avatar
2019 e 450 cabriolet
my current E - 450 cab and my 2 previous SL 550's did this as well.
Old Jun 4, 2019 | 12:38 PM
The_Judge's Avatar
2018 E400 Coupe
I suspect that the fan has to work harder to move the same amount of air when the roof is raised (and windows closed) as opposed to when it's down. Simple physics — when the roof is up, the fan is blowing into an enclosed space, which requires more effort (energy) than when it blows into an unenclosed space. It's a bit like the difference between blowing up a balloon and just blowing hot air.
Old Jun 25, 2019 | 10:23 PM
jimzbenz1's Avatar
2018 E400 Cabriolet
Regardless of how hard the fan has to work when the top is up or down, the a/c fan speed increases quite noticeably when putting the top up. Though the top fan speed is "7", a 7 with the top down is not as strong as a 7 with the top up.
On Audis, the opposite is true, the fan speed of the a/c increases when putting the top down. Audi engineers have apparently actually been in a convertible, and note that it is often hotter with the top down, and thus chose to increase the fan speed to provide additional cool air when it's needed most.
