E-Class Coupe (C238) & Cabrio (A238) 2017 - E200, E220, E300, E350, E400, E450 [Coupes &Cabriolets]
2011 E350 Cabriolet Auxiliary Battery
Old May 24, 2020 | 02:30 PM
xelsco's Avatar
2011 Mercedes e350 Cabriolet
Does anyone know where the Auxiliary Battery for the 2011 Mercedes e350 is located.
It's Not in the trunk or the driver side dash panel as i have seen in videos. Please help.
Old May 24, 2020 | 03:50 PM
konigstiger's Avatar
'71 Pinto
No auxiliary battery only one battery. Continue posting to your original thread: https://mbworld.org/forums/new-membe...tart-help.html you need to have it towed to dealer to pull fault codes using MB diagnostics. Check f7 (20A) at front fuse box in left engine compartment. If fine, since both keys are inoperative it “could” be your electronic ignition switch (EIS). BTW, for future reference 207 should be posting here: https://mbworld.org/forums/e-class-c...brio-a207-141/
