E-Class Coupe (C238) & Cabrio (A238) 2017 - E200, E220, E300, E350, E400, E450 [Coupes &Cabriolets]
Gas Gauge
Old Jan 1, 2025 | 06:52 PM
Mgrace47's Avatar
Gas Gauge
Is the distance estimate for the gas gauge accurate on the MBUX display and how much can I trust it? Thanks.
Old Jan 2, 2025 | 07:12 AM
MikeO3's Avatar
2018 E400 Coupe C238
I have never run out. There are about 7l as reserve which should work out to roughly 75-100Km depending on consumption.
Old Jan 3, 2025 | 02:04 PM
Grant_J's Avatar
'18 E400 Cab
When it says you're about out of gas, fill up and you'll always be fine. The gauge can be trusted that you won't run out if you do that. I've let mine go below where it just turns red and stops giving a number, still ok for at least 20 miles/25+km.
Old Jan 3, 2025 | 02:37 PM
Mgrace47's Avatar
Gas gauge
Thank you for the responses very much appreciated.
Old Jan 3, 2025 | 04:25 PM
W205C43PFL's Avatar
Well, accurate or not, to be honest I never recommend letting it run below half a tank, the lower it is the less gasoline is there to cool the fuel pump which would cause damage in the long term plus lower gas also result in higher condensation in the tank (from what I heard).
