Triple 40mm Webers
Triple 40mm Webers
Heyall
just playing with a M110 I have laying around that I thought I would post up for anyone else wanting to play.
Limited info out there around this project.
So the 40mm-45mm Weber Side Draft throat spacing is basically spot on what the M110 inlet ports are which is a bonus as one only has to buy the Weber flanges off Ebay and then cut a base plate mirroring what the inlet face looks like on the M110.
You have to do this as the bolt pattern is totally different on the manifold as to the flange plates for the Webers.
I have some pics but can seem to post them up.
Anyway I am hoping for my manifold gasket to arrive to use as my template to cut ports and mount it all up and the linkage is dead easy as well.
Peter
Peter
