E-Class (W114/W115) 1968-1976: All Models
Crankshaft pulley noise/wobble 72 220D
Old Jan 6, 2023 | 08:41 AM
Fourtyres's Avatar
1972 220D W115
Squeaking noise from belts-tightened alternator-got worse-the pulley is wobbly looking-noise increases with RPM, going to check bolt for tightness but unsure as to replacement procedure if necessary-does this vehicle have a harmonic balancer? Newbie to W115, had several W123. Any help greatly appreciated!
Old Jan 17, 2023 | 09:44 AM
Fourtyres's Avatar
1972 220D W115
Also is bolt 27mm as I've seen and can I remove by putting in high gear to avoid buying removal tool (read that somewhere) ??? Thanks!
