E-Class (W123) 1976-1986: 240D, 280E, 300D, 300TD, 300CD
New A/C rattle - With VIDEO - Help W123.133
Old Jun 16, 2007 | 11:38 PM
DieselBenz.info's Avatar
Greetings my dieselbenz brethern,
W123.133 - 1982 300dD-Turbo
So I bought a new AC Compressor, Dryer and Evaporator. I installed them all, and all was well.
I used this guide http://dieselgiant.com/repairyourac.htm
Eveything went well except when installing the AC Compressor, lots of the synthetic Esther oil leaked out. I couldn't get the bolts on fast enough. I don't know how they expect you to keep it all in there when installing it, when you have to tip it on it's side to install it. Anyways. I turned on the A/C with no refridgerent in there for a few seconds, and all sounded well, (to see if any belts rubbed, etc.) Then I put in a can of R12 "equivilent" and then ran it for a bit, and all was well. Bubbled checked out in the new Dryer, all was well. I then tried it again and then all of the sudden I get that terrible sound. Here is the video, (useless) except the AUDIO is what I want you to listen to.
http://video.google.com/videoplay?do...81935737&hl=en
At time point 6 seconds, I turn on the AC and you can hear the rattle (kinda, it's a mercedes diesel, right?) at time point 12 seconds, I turn it off. Notice the difference. When it's on, it sounds like a bunch of rocks are rattling inside it or metal on metal sound, NOT GOOD. So I dare not to use it until I figure out what's up.
So... what's up? What did I do wrong? I did put some Esther oil in the Dryer as well, as directed from DieselGiant.
Old Jun 17, 2007 | 08:09 PM
POS's Avatar
POS
1966 250SE Cab, 1985 500SE Euro, 1985 190e 2.3-16 AMG, 1986 300E LeMons Car
A noisy compressor is a bad compressor - bad bearings inside. Sounds like you need to get another one. Did you buy a good compressor or a cheap one?
