E-Class (W123) 1976-1986: 240D, 280E, 300D, 300TD, 300CD
Stalling Compressor a Symptom of Failing Expansion Valve?
Old Sep 4, 2007 | 02:16 AM
zigurat's Avatar
2006 S65
My 1979 240D has 94,000 miles on it. The air conditioner (York compressor and r-12) cools quite well while moving. However at idle, the belt slips over the compressor pulley and squeals loudly. I had the belt replaced and correctly tensioned, but the problem persists. The shop believes this is due to a failing expansion valve, and wants $300 to replace it and recharge the system. Could a bad expansion valve cause this problem?
Old Feb 19, 2008 | 08:48 PM
tanktube67's Avatar
2008 Black Out C350 Saks Edition / 87 VW GTI
The expansion valve has nothing to do with the belt; the expansion valve regulates the circulation of the Freon.
Take a look at the a/c clutch if you see a big gap and if smells like if is burning.
Or take a look at the pulleys may be worm out
